Simple Rodeo Lift
So, I'm considering whether or not it's worth it to shell out a couple hundred bucks to get new shocks and shackles to lift my Rodeo. I remember reading somewhere that the stock torsion bars are suitable to use for offroading and that they really don't need to be replaced unless they are worn out. Calmini has shackles for 50 a pair and 40 for each shock. I just want a quick 2 in. of lift to fit 32's on it. Also, would it be a must to re-gear the differential? I don't know what the stock ratio is but i think its between 3.5-3.8. Beside the point, the CV axles were replaced two years ago so I believe the front end is kosher.< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-44";
pittbeall
IF Help & Suggestion Center
06-16-2011 03:22 AM
