Rodeo Windows dont work from driver door
Hi, I hope that someone can help me as I don't really waant to have to take this to a main dealer.
My electric windows will no longer operate from the drivers door on my 2006 Rodeo. They will operate from other doors. Even the child window lock on the drivers door no longer operates.
To be honest this happened after I had installed a new horn when I routed the wiring through the bulkhead so probably my own fault unless a big co-incidence.
I have checked ever single fuse, relay and all connections on every single connector block under the dash and can't find anything wrong.
I have also tested the supply to the back on the control switch on the drivers door and can't get a feed. Everything else on the control switch works i.e. electric mirrors and lock.
Could anyone suggest anything or point me towards a wiring diagram etc. as I've come to the end of the road with this one.
Thanks
Snake
_uacct = "UA-939292-44";
