rodeo power windows quit working...
hey hi,
I have a 95.5 rodeo that is having some trouble, hopefully one of you can help me to track down what is going wrong. back in december we got a huge wet snowfall and during this I blew the dash lights fuse (replacing the fuse fixed this)and the power windows quit working. I thought it was probably the 30 amp manual reset breaker, and tried a 30 amp fuse in that slot which worked but since the fuse didn't fit correctly it dropped out while driving, it didn't fry and was still good but now the windows are not working again. the breaker tests ok to me(I can get current through it), and the fuses I have tried are good too but the windows don't work whatever I do, the relay doesn't appear to be the problem as I swapped another into that slot but still have no windows working. the master switch on the drivers side(left) was starting to have trouble as in 2 of the switches didn't work both directions, so I guess it is possible that the switch went bad. my chilton manual doesn't have the power windows included in the wiring diagram, and I'm feeling like I am beating my head against the wall.... anyway, has anyone had this type of trouble? know how I should go about diagnosing the trouble? I'm struggling here, so any ideas or theories are appreciated, alec |
| All times are GMT -5. The time now is 06:07 AM. |
