I jus bought a 1994 4wdisuzu trooper $2,000. its in great condition,no leaks 117k miles, auto....Can anyone tell me why this suv roars really loud before it gets to about 40 mph? And also, the engine smells like gas really bad on the passenger side, i have no idea where it can be coming from!! Ive never owned one of these, i used to collect classic bmw's so this is a big change!Someone please help me thanks! Oh and also, the front passenger window doesnt operate and either does the rear passenger window. but front driver side works and so does the rear driver side. !? [img]uploads/trooper88/5294D_my_trooper.jpg[/img] email- shutupandsurf04@yahoo.com-StuartEdited by: trooper88 |
roars? i dont understand...
OK roars my 86 Isuzu trooper dose the same thing might be your tires if you have m/s all season's on it there meaty tires and can cause a roar i have had this experience. also check your fuel pump they have a hose that goes straight down and its to let you now that your fuel pump is going bad its a weep pipe. mine smelt like gas bad and i checked it and it was my fuel pump going bad. changed it and all is OK now. i hope this helps you out. Edited by: cruser92
What engine does your trooper have? I don't know about the V6 but I know my 2.6L amigo 4 banger is equipped with an air pump (stupid emissions law says that if your car came equipped with it, you have to leave it there, and it has to work too, or you fail emissions..atleast here in NJ) But anyway, The air pump is LOUD, and it definately ROARS. It's intermittent, turning on and off when it needs to, mine comes on mostly when i first start the engine and it stays on for a few mins, or a few miles. You are probably hearing your air pump, that would be my best guess. |
also watch the fan clutch operation,it may not be releasing right.when there fully egaged hot they normally pull alot of air to coool the radiator,if its not disengaging you.ll here the loud roaring on acceleration.esp aftermarket ones
