biglou |
01-08-2007 03:44 PM |
Hi you gave me some good info on the check engine light on my 99 amigo 2.2.I told you in earlier posts that the light comes on and goes off every couple of days.I changed the motor myself and you said that the dealer would have to do a procedure to have crank sensor relearn .I called the only dealer around and they acted like I was talking french.I changed the cam senor again which they said was bad,the code comes up multiple misfire and they said cam sensor was bad and that it came up when they scanned it,well I changed sensor and it came on again.Is there anyway I can get someone else to do this procedure,my friend has snapon tool can I get program for it or something.This is the only delaer around.thanks so much LOU
