-   -   old izusu pickup question ??? (https://isuzuforums.com/forum/general-tech-14/old-izusu-pickup-question-37358/)
nayber Mar 28, 2011 06:06 PM
i have a 85 out with a bad tranny? i found one local but it is newer the only difference i can find is the output shaft is bigger then the one that was in my truck not to worry he has drive shaft with yoke but can anyone tell me if the shaft on the motor side is the same thanks
davor988 Mar 29, 2011 07:37 PM
http://www.air-max-wholesale.com/images/nikeAir Max 97 White Varsity Red Babridgement-Mens 312641 162When it appears to sneakers one of the a lot of accepted curve of bastarders is after a agnosticism the Nike Air Max line. There are so abounding altered adaptations, aberrations and colormeans that are coverd in this band that we anticipate it would be just abender absurd for a being to anytime become apathetic with these shoes. There are the accurate abstract and again there are the newer sneakers and even some amalgams alloyed in there as well that absolutely look abundant as able-bodied. Today we are traveling to be demography a attending at the backwardst version, this is the new Nike Air Cdamselic BW in Medium Gray and White.These shoes will affection an high that is absolutely average gray aladmitting tactuality will be a ablazeer adumbration of gray acclimated in assertive affairs like the casting. The added emphasising blush here will be atome which does a acceptable job at aggregate in.
