Missing or Vibration at idle...
Old Jan 28, 2009 | 06:50 PM
concreteguy's Avatar
I looked through the forums to see if there was a similar issue before posting. I have a ''95 rodeo V6. Here recently I have been having issues with what seems to be a miss or bogging down of the motor at idle, while in gear once stopped. This issue also seems to happen while driving between 40-50 Mph after the transmission has down shifted and I am only pressing on the gas to maintain my speed. If I press on the gas to accelerate the problem goes away. I have changed the air filter, fuel filter, plugs, erg valve is about a year old. Any suggestions??
Old Jan 29, 2009 | 03:28 AM
kurtdaniel's Avatar
If the back tires are not evenly worn, it will cause the steering wheel to shake as you come to a stop..
[img]smileys/smiley11.gif[/img][img]smileys/smiley3.gif[/img][img]smileys/smiley10.gif[/img][img]smileys/smiley17.gif[/img]
hp?act=post&do=rehp?act=post&do=re
kurt E. danie''s push bars</span>
rum/forumdisplay.php?f=1/key_/</font>
Edited by: kurtdaniel
Old Jan 29, 2009 | 06:32 AM
Its not the tires. It happens once stopped, when I start to drive, and between 40-50 Mph.
Old Feb 17, 2009 | 11:25 PM
robb5's Avatar
my 98 v6 does the same thing, I suspect it is the TPS throttle position sensor. Bad stumble?
If It is worn or dirty and is reading a voltage variation at idle or cruiseit is trying very hard to meet what it thinks you are requesting as a new power setting.
grone79
Jan 5, 2009 10:57 PM
rdsett
Dec 15, 2008 12:43 PM
soundman
Sep 23, 2006 02:21 AM
brokenRODEO
Jun 23, 2005 04:03 PM
greg
Mar 15, 2005 12:12 AM
