Missing or Vibration at idle...
I looked through the forums to see if there was a similar issue before posting. I have a ''95 rodeo V6. Here recently I have been having issues with what seems to be a miss or bogging down of the motor at idle, while in gear once stopped. This issue also seems to happen while driving between 40-50 Mph after the transmission has down shifted and I am only pressing on the gas to maintain my speed. If I press on the gas to accelerate the problem goes away. I have changed the air filter, fuel filter, plugs, erg valve is about a year old. Any suggestions??
If the back tires are not evenly worn, it will cause the steering wheel to shake as you come to a stop..
[img]smileys/smiley11.gif[/img][img]smileys/smiley3.gif[/img][img]smileys/smiley10.gif[/img][img]smileys/smiley17.gif[/img]
hp?act=post&do=rehp?act=post&do=re
kurt E. danie''s push bars</span>
rum/forumdisplay.php?f=1/key_/</font>
Edited by: kurtdaniel
my 98 v6 does the same thing, I suspect it is the TPS throttle position sensor. Bad stumble?
If It is worn or dirty and is reading a voltage variation at idle or cruiseit is trying very hard to meet what it thinks you are requesting as a new power setting.
