major engine troubles
What engine/vehicle do you have? Do you want a complete used engine or a remanufactured short/long block?
I don''tthink you''ll find a GM engine that will "bolt up." You could use lots of different engine transmission combo''s though. It all depends on you and how crazy you want to get with the cheeze wiz.
Tony
It''s a 2001 rodeo ls.i could go for just a long block.what happened was i threw a rod through the block lol.is this a natural thing for isuzu''s? i''ve seen alot of people on here talking about things goin wrong.i''ve only owned it for 4 months.i''m already discouraged.
I have a 1989 Amigo w/ a 2.6 liter. I''ve driven the *&@# out of it for 3 years. I did buy a donor Amigo and the block had a hole in it from some catastrophic engine failure. It happened just after they put a new rebuilt head on.
What size is the engine? Maybe look on ebay or call around to local wrecking yards.
<h3 class="smller">engine problem</h3>
hey guyz m havin dese strange problems...
1. ven i start ma bike in da morning and leave da throttle, da rpm goez dwn till 500, stays dere for abt 4-5 secs, and den da <b style=": rgb(255, 255, 102);">engine[/b] shuts dwn...
after da bike is completely warmed up, it goes way up.... till 1800-1900...
2. whenever i increase throttle, da <b style=": rgb(255, 255, 102);">engine[/b] rpm takes time to go up and doesnt **** dwn instantly ven i close it... da rpm goes up and dwn very slowly..
even ma top speed is only 101-103kmph and da mileage hz dropped drastically by 10-12kmpl
