< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> Im having an issue with my rear turn signals on my isuzu hombre. rear turn signals will not blink/work, fronts work but blink faster then normal, checked relay in glove compartment(this clicks loudly and very fast, so changed it out, but still with same issue), fuses on side of dash, inside engine compartment, relay inside engine compartment, cant find a problem with any of that, ive changed the bulbs and ensured they are working, hazard lights work just fine. Other then maybe a wirring issue im not sure what the issue could be or where it could stem from, any idea's would be apreciated... Thanks, Travis |
