Hi I need to fit a new clutch kit in the master cylinder in my 1993 Bighorn 3.1 Diesel. Any help with removal instructions appreciated. Edited by: lemuzz |
need some clarity. your doing a clutch kit? or your doing a master cylinder? or both ? all thoug a big horn is a non us model. umm mabey call a local shop an see if you can ask for soe info. most places will print it out for you. all so if yuor going to work on your own i would advise buy an manual for it. so that you can follow all the proper specifications.
if your putting in a new master cylinder you may want / need to bench bleed it first. |
