Help with torque Specs Please!!! 2.2L Engine
Hi all, I have a 2001 rodeo with the 2.2L, now kind of taking care of leaks and stuff, freeze plug got out after it got overheated, does anyone have the service manual for it, willing to share? Need torque specs for: Valve cover Oil pan Intake manifold Throttle Body Thermostat housing Proper way to install freeze plugs Thanks in advance. |
Torque specs
Valve cover 83 in-lbs
Oil pan 70 in-lbs Intake manifold 16 ft-lbs Throttle Body 16 ft-lbs Thermostat housing 132 in-lbs |
hahahha
