Help on crankshaft seal
Old 07-19-2007 | 08:33 PM
qha000's Avatar
Hi all,
My 92 trooper started a major oil leak yesterday and I was told that the rear crankshaft seal has broken. Any idea how involved it is to change that as a DIY project? Thanks.
Old 07-20-2007 | 09:26 AM
ISUZUGURU's Avatar
Super Moderator
it can be challenging to the unexperienced,the most problem is getting the exhaust out of the way.but its pretty cut an dry,just move the trans,flywheel,take out the old seal an install a new one,doing this on the ground in your driveway or somthing is always a pain.
Old 07-20-2007 | 01:27 PM
qha000's Avatar
Thanks , so what's the correct name for this seal? Is it the crankshaft seal or transmission seal? I'm trying to price it and was wondering if you knew the exact info. Are there any write ups out there? Thanks
Old 07-20-2007 | 04:51 PM
ISUZUGURU's Avatar
Super Moderator
its called the rear crankshaft seal,or rear main seal.
Old 07-30-2007 | 08:38 PM
qha000's Avatar
Thanks for all the help. I mangaged to pull the transmission and clutch ***. down this past weekend and replaced the seal. Are there anything else I should change before putting it back together? Thanks.
donandsue2
08-07-2020 07:21 PM
Gdafpaaa
07-05-2011 05:07 AM
99amigo2.2
02-18-2009 12:00 AM
barber1
11-03-2007 10:04 PM
rja4u
05-04-2007 09:15 PM
