Getting the Spare Tire Down
On a 1990 pickup with the temporary-use spare under the bed, anybody know how to get it down?
The manual says to put the hooked end of the tire wrench on a slot on the spare holder and turn cc to winch it down. I assume the tire wrench is the L-shaped tool with a wheel-nut socket at the end, and the "hooked end" is the end with the socket. If so, nothing remotely fits the spare holder. |
I had to use a hacksaw and cut the chain.
Thanks, but I figured it out. There's a long rod hidden on clips behind the seat-back top. There's a hole hidden near the rear licence plate. Insert the rod into the hole. Turn the rod using the jack handle. That turns gears that lowers the chain.
Clever system, poorly-written manual. |
Hi...
thanks for posting your message ! I hope you would find out a good message of your post that would be sufficient for you ! |
Originally Posted by alanauer
(Post 46965)
The manual says to put the hooked end of the tire wrench on a slot on the spare holder and turn cc to winch it down. I assume the tire wrench is the L-shaped tool with a wheel-nut socket at the end, and the "hooked end" is the end with the socket. If so, nothing remotely fits the spare holder. hey important news sere you thanks |
Thank you, Taylor.
How long have you been out? |
Originally Posted by Brandt
(Post 47065)
