Dmax 2013 failing transfer box
Failing 4wd on my Dmax changed the change over controller on the back of the transfer casing and the actuator on front axle . It selects 4wd but I have a very loud grinding then it engages after grinding and crunching . After closer inspection to the oil in the transfer box it's black with a hint of glitter . . My guess at this time that the transfer box is buggered. .and when driving under strain ie not changing down quick enough I have a loud rumble sound like a failing bearing . .
