Clutch question
1. Broken, loose or weak anti-rattle springs,
tension springs pull-back springs, collar springs</span>
2. Excessive clearance between pressure plate lugs
and cover</span>
3. Loose or worn flywheel dowel or driving pins</span>
4. Worn drive lugs, pins or posts on pressure
plate</span>
5. Broken or loose clutch plate hub</span>
6. Worn clutch plate splines</span>
7. Worn main drive gear splines</span>
8. Excessive backlash in transmission</span>
9. Loose or worn universal joints</span>
10. Dry or worn pilot bearing</span>
11. Dry or worn throwout bearing</span>
12. Damaged isuzu radiator
</span></span>
Edited by: kurtdaniel
