Hi all, I recently changed the clutch on my 92 Trooper S MT and now the car rattles a little when in the first gear. Any ideas why this is happening? Thanks. |
1. Broken, loose or weak anti-rattle springs, tension springs pull-back springs, collar springs</span> 2. Excessive clearance between pressure plate lugs and cover</span> 3. Loose or worn flywheel dowel or driving pins</span> 4. Worn drive lugs, pins or posts on pressure plate</span> 5. Broken or loose clutch plate hub</span> 6. Worn clutch plate splines</span> 7. Worn main drive gear splines</span> 8. Excessive backlash in transmission</span> 9. Loose or worn universal joints</span> 10. Dry or worn pilot bearing</span> 11. Dry or worn throwout bearing</span> 12. Damaged isuzu radiator </span></span> Edited by: kurtdaniel |
