brakes
i have a 1986 trooper and brake pedal goes to rhe floor any suggestions
What have you done?
I recommend to flush the brake fluid out with DOT 4 Synthetic brake fluid... Buy one of the big bottles and bleed the system until the fluid comes out of the caliper bleeders crystal clear... This alone should do the trick... If that does not work check all your brake pads and brake shoes for wear and unusual wear... Replace as needed... Luis |
The Spyder designer team has a lot of talented designers, as we can see by taking a look at the 2009/2010 Spyder catalogue.
The upcoming 2009/2010 models - an upgraded Pilot and an Electra from the Classic series; the upgraded semi-automatic Spyder models 'Xtra', 'Sonix' and 'Victor' all look great, and what's even better - the fans have learned to trust them. The new electronic marker, MR2, is a design masterpiece, with its trigger standing out from the marker crowd with its ergonomic positioning. MR1, an upcoming semi-automatic marker has the same trigger and a rifle-like overall design, giving extra props for the cover players, and in capture the flag, when the players don't have all the time in the world when they need to aim.
_________________________ skateboard bearings |
You buy the perfect item at an unheard of perfect price. Wouldn't it be fantastic if you could get that adjustable bed you've had your envious little eyes on for quite some time at an amazing price. Not only would you enjoy that deep rejuvenating sleep on your new adjustable bed, you would also be able to watch your friends turn green with envy at your shopping prowess. You would be hailed as a shopping dynamo...a market wizard...a master negotiator...a lord among peons.
Good message about the brake shoes and pads really awesome
