I have a ’96 Rodeo, 3.2L V6. Recently, for no apparent reason, it has been blowing a fuse which causes the engine to shut down. The fuse is the CB-3 fuse (Engine Device), 15 amp, in the interior fuse block. I have tried a number of things with no luck. In my wiring diagram it shows this fuse is directly connected to the Ignition Control Module and the Electronic Control Module. Beyond that I don’t know more. I have noticed that when the fuse blows, when the key is turned to ACC, the Check Engine and Check Transmission lights do not come on. There is nothing consistent about the fuse blowing. It could happen twice a day, or once every two or more days. There is nothing particular going on when it blows other than the fact that you are driving down the road. I have had it at two different shops and none of the mechanics could find the cause. I have also tried searching the internet with no luck. Has anyone seen this situation? Or, have any ideas? Thanks in advance. John Edited by: jbcol1 |
If you have some sort of path to the ground or what you call a short circuit.. that is the main reasons why fuses blow..
********** [img]smileys/smiley11.gif[/img] hp?act=post&do=rehp?act=post&do=re Autopartswarehouse kurt E. daniel rum/forumdisplay.php?f=9&PN=1</font> |
engine device fuse
I too have had this problem but only once so far just recently. I have spare fuses but also want to know what this does. My wiring diagram says it controls the ECM main relay which powers all sorts of sensors and the fuel injectors. So I'm thinking that the ECM relay coil is overheating and needs replacing. That's just a guess.
