95 trooper manifold to Y pipes???
I am being given a trooper and i'm not going to take it after working on it today and then coming home and finding out the pipes to the manifolds are discountinued. It's an a/t 1995 3.2 sohc. I welded the one pipe for now, but i'm not going to replace the y pipe and not the y to manifold pipes.
It's bad enough there's a hole in the frame by the rear hitch bolt location on the d/s. I can not believe isuzu managed to get away with this ****. The body is mint but the frame is rotted it has 120k and a frame as bad as the rodeo and tacomas i've seen. Maybe not as bad as the tacomas, but wtf? If I could at least get the pipes id just drive it into the ground. It's a nice looking vehicle too bad they chose the wrong frame manufacturer. |
Does anyone know where to get flanges? What diameter is the pipe and whats the bolt spacing? Thank you
I misread macs has it.
http://www.macautoparts.net/Exhaust-5814/3013332-95-Isuzu-Trooper-Engine/ProductInfo.aspx |
Try checking Auto Parts Warehouse.
