-   -   91 trooper injector problem (https://isuzuforums.com/forum/general-tech-14/91-trooper-injector-problem-39200/)
Mj4442 Jun 17, 2012 10:22 AM
Have power on both sides of my fuel injectors but can't get them to fire......and they are new injectors
Hudson9 Jun 21, 2012 08:16 AM
yah I am not sure about that, i would try both; cant hurt. also i would try holding the gas down once you jump them, cause that should throw code 51(i think) for sure. i would also pull your efi fuse for a min to try and reset that damn CEL, i know when you disconect the bat it resets it too but...
did you disconect your bat first thing when you started pullling your head, dont think i've heard of the cel staying on solid when checking codes.
thats the schematic i was reading, remember you cant have voltage drops if current isn't flowing, thats why you see 12volts in, 12volts out, ONLY if it was plugged into the injector.
never used nor learned about those 'noid' lights.
Car Performance Parts
fourtsprint Jul 13, 2012 09:46 AM
got a 91 trooper 2.6 the idel goes up and down and is running very rich, any ideas?
