< src="http://www.google-analytics.com/urchin.js" =text/> </> Hi. I have an 89 trooper with a 4 cyl 2.6L in it. I needed to change the water pump and head gasket. while i had the head off i did a valve job also. I had a vacuum hose that i was unable to find where it went so i took a look at another 89 trooper with the same engine and figured that vacuum hose out. I turned the key to start it up and it starts right away and sounds good. But it dies right after it starts. I can keep it running by holding in the gas but as soon as i let go it dies. It's gotta be something stupid that i can't figure out. If some one out there has any suggestions i'd be very thankful. |
| All times are GMT -5. The time now is 08:07 AM. |
