| tinribs |
Jan 22, 2024 01:30 AM |
2014 DMax air con cutting out when engine hot
Any clues to find the cause of the air conditioner shutting off when the engine temperature in my 2014 Isuzu DMax increases to about 'mid gauge' right about when you most need it with ambient temperature around 30 degrees plus. With an after market OBD monitor, engine temp is around 100 degrees C. When temp reduces below mid point, A/C unit comes back on. All control switches work fine, gas level checked OK, belt tension OK, Everything works as it should just not when engine gets warm/hot but not overheated. I am thinking maybe electronic thermostat but that's only a guess as I can't seem to put a finger on anything else as the culprit. Any thoughts or similar experiences welcome. Thanks.
