when stopped and i give it more gas then usual, it starts to shutter like big time, seems like its from the front end, feels like the front axle is going to fall off, might it possilby be not diengaged from 4x4? or does it sound like a tranny problem?, anyone ??? |
Check the transmission fluid level. Also if it low check for leaks, the most common leak is the accumulator piston cover on the right side of the transmission. When this trans gets low it will shudder very bad on accel and if left unchecked will cause major internal damage.
