1996 Trooper tranny issue
Hello to all. I am new to the Isuzu forum. I have a 1996 trooper with 209,000 miles. Works well when first started, but after a short stopping it feels like it slips when taking off in drive. Sometimes all the lights on the dash come on, and radio goes off than it starts with the same symptoms. It will take off well when shifting manually, but when you shift to 2nd there is a shudder, but smooth when going to 3rd and drive. Since tranny is electronically controlled, is there some sort of downshift selenoid that can be checked? Don't know history of vehicle since I have only had it a short time. Any suggestions would be apprecicated. I am trying to find a mechanic who actually has experience working on Isuzu's.
Took Trooper to a small transmission shop who works only on foreign vehicles. He told me that electronics were good, and transmission was low on fluid. He filled it up and I have driven it over 100 miles today in traffic, and out on the open road on several trips. No problems at all.
this is the same problem i am to facing and want to know the more stuff on it.
Is there some sort of downshift selenoid that can be checked? Don't know history of vehicle since I have only had it a short time.
Many states have public websites with the names of people who have been in prison or are registered sex offenders. Where I live, a criminal background check can be ordered from the county sheriff for a small fee.
_______________________ Online fish games|Fish tank games |
Considering the fact that you spend a third of your life on your mattress, it's important to ensure that it remains in good condition. If you wake up sore and irritable every morning or if there is a dip in the center of your mattress, these are signs that you should get a new one.
At first, you may have to remove the skateboard wheels by inserting the skate tool into the pocket of the wheel and turn counterclockwise, exerting firm pressure until the wheel comes loose. Remove any bearing shields and spacers from the wheels.
____________________________ skateboard bearings |
Trooper transmission problem
Hi II have a 1995 Isuzu Trooper with transmission problems. This is more or less the drift of it, hopefully someone can give me an idea.
When you put it in drive it takes off in second gear. When you put in low gear it stays, but if you put in second gear it rolls backwards then rolls forward. Like its trying to go into two gears at once. Once wheels start rolling, you put in third gear goes smoothly. If never goes into overdrive. Makes no attempt at all to go into overdrive. TCM has also been replaced to. Oh and we bought another transmission and it's doing the same thing. Anyone have an idea about this? I sure could use some input on this please? |
