-   -   1993 TROOPER CLUTCH PROBLES (https://isuzuforums.com/forum/general-tech-14/1993-trooper-clutch-probles-866/)
EDDYFLY55 Feb 16, 2007 04:52 PM
I just put in a clutch plate in my trooper and when I went to start it the clutch pedal was very hard to push. So I bleed the clutch and if felt right but would not disengauge.The next day I noticed I had no fluid and when I added it I tryed to bleed it but the it wouldn't do anything the pedal keep going to the floor and there was no pressure at all no matter how many times I tryed ti bleed it.
Any ideas
MASTERTECH Feb 16, 2007 09:26 PM
look at the clutch master cylinder and the slave cylinder
when you look at the master cylinder look inside where the rod comes through the fire wall, and look on the ground or around the slave cylinder
