-   -   1989 Amigo fuel return line Q (https://isuzuforums.com/forum/general-tech-14/1989-amigo-fuel-return-line-q-99/)
eippermx Jun 18, 2005 02:07 AM
I was given a 1989 Amigo with a 2.3 ltr. motor that had bad valves and was partially torn apart. I havereplaced thecylinder head with a rebuilt unit and have the entire engine back together except for 1 thing...The fuel pump has three ports, according to the book, the Top port - return port, middle port - fuel input, and the bottom port is the fuel output to the carb. My problem is thatI don't know where to connect the fuel return line.I've look all over the intake and carb for a nipple to hook the rubber line to but have been unsuccessful. Can some please help describe where to look tohook the other end of the return fuel line?
Patrick Jun 18, 2005 01:41 PM
if you check with an dealership parts department, they should have access to schematics of sorts...to help you out...i know that when i worked for a dealership, we would help people with things like that
