-   -   02 Axiom Clock and compass will not set (https://isuzuforums.com/forum/general-tech-14/02-axiom-clock-compass-will-not-set-317/)
ennis1979 Feb 22, 2006 05:50 PM
I have a 2002 Isuzu Axiom. The clock and the compass will not set. I read in the owner's manual and supposedly the clock and compass are supposed to be set by satellite. The manual stated that if for any reason the clock/compass should be incorrect you need to disconnect the negative battery cable for 3 to 5minutes and then reconnect. The car should then read the new satellite signal and correct the issue. I have done this and now 3 days later I still have no compass or clock. Any ideas on what to do for this?
ISUZUGURU Feb 23, 2006 03:40 PM
TAKE IT TO YOUR DEALER,GPS SENSOR MAYBE BAD WHY ITS NOT PICKING UP THE SATELLITE READING.
