-   -   00 amigo stalling (https://isuzuforums.com/forum/general-tech-14/00-amigo-stalling-878/)
rowdyburns1 Feb 22, 2007 03:22 PM
my 2000 amigo was taking way too long to fire up when cold , stalling at stops and running badly at idle - once up to speed ran great - took to dealer they said intake gaskets so i had them done ($300) went and picked it up and it didn't stall anymore but still didnt run right and still took forever to fire when cold (i also looked at the engine after i got it back and it didn't appear that the intake had even been removed but i couldn't tell for sure) now it is stalling again and they want another $300 for intake gasket(s) - any ideas appreciated thank you
4L4N Feb 24, 2007 04:40 AM
you should run a pressure test done on your intake system. If you have a vacuum leak it will f**k with your idle
steve isuzu Apr 1, 2007 06:05 PM
your problem is the fuel psi regulater just pull the vacume hose off and watch the fuel come out of the hose now repolace it it should take about 45min to do any questions just email
