What is a car chassis? Types of chassis frames explained
Unless you're a car enthusiast, you probably don't know the technical details of your car. But knowing them can help you understand the actual potential and limitations of the car you want to buy. Automobile chassis is one of the important technical indicators of automobiles.
What is chassis in a car?
The chassis or frame is the main support component in a car’s structure. It bears the forces experienced by a car while it’s standing still or moving at high speeds.
A vehicle chassis is like a human skeleton. It provides the structural shape and support to the entire body of a vehicle. The role of this structure is to keep the car intact while experiencing the forces of driving, turning, braking, etc. Some of the key functions of a car chassis are mentioned below.
Functions of an automobile chassis
It supports and handles the car’s load.
It provides mounting locations and spaces for multiple parts of a car.
It withstands and supports the added pressure of the luggage and passengers in a car.
It manages the stresses on the vehicle while driving in rough road conditions.
It manages the stresses on the vehicle during acceleration and braking.
While the basic functions of a vehicle chassis remain the same, not every vehicle is manufactured with the same type of chassis. The form varies based on the type and purpose of a vehicle.
How many types of chassis frames are there?
Based on the application, the following are the major types of chassis in cars.
Monocoque chassis
Ladder chassis
Backbone chassis
Tubular chassis
We have explained all four types of automobile chassis in detail in the following sections.
What is a monocoque chassis?
Monocoque is one of the most commonly used chassis frames in cars nowadays. It is a single-body structure that constitutes all mechanical parts and other components.
Thus, components like the exterior panels, seats, suspension, engine and gearbox remain attached to the frame construction. It allows the overall vehicle construction to stay compact and lightweight. This is why a monocoque chassis is popularly used in compact and small hatchbacks.
A monocoque vehicle chassis is also considered highly safe, which makes it a suitable choice for the construction of modern compact SUVs (Sport Utility Vehicles).
Advantages of monocoque chassis
Compact and lightweight structure makes a monocoque chassis perfect for small vehicle construction.
Due to a single-shell structure, the chassis can easily manage dynamic forces and maintain stability while taking turns.
The cage-like design adds to the safety of the car as well as the passengers.
The lightweight construction helps to create budget-friendly cars with high fuel efficiency.
Disadvantages of monocoque chassis
The single-body structure makes a monocoque chassis stiff, which reduces the off-roading abilities of the car.
The single-shell structure makes it difficult to repair if required.
What is a ladder-on-frame chassis?
The body on a frame or ladder frame chassis is heavily used in the manufacturing of SUVs, especially the SUVs that are supposed to have off-roading capabilities.
This type of chassis contains two heavy beams supported by smaller ones. The cabin and chassis are constructed separately and attached later. The frame provides a layer of protection between the cabin and the road, enabling enhanced off-roading capabilities.
Advantages of a ladder-on-frame chassis
A ladder frame is quite easy to assemble.
Separate constructions of chassis and cabin make ladder frames useful for different kinds of car bodies.
This chassis is highly flexible and agile, which gives better off-roading capabilities to the car.
The separation between the road and cabin due to this frame provides a quieter and more comfortable driving experience.
Disadvantages of a body-on-frame chassis
The increased height of the car’s structure requires more effort and attention while driving.
The heavy components of this automobile chassis are not suitable for hatchbacks or sports cars.
What is a backbone chassis?
The name ‘Backbone chassis’ reflects the shape of this frame. It contains a rectangular hollow cross-section with a cylindrical tube that passes through it to connect the rear and front suspension. This creates a human spine-like structure, giving it the name backbone chassis.
Advantages of backbone chassis
This frame structure provides better connectivity between the axles and the ground.
The car with this chassis gets more stability than other chassis options.
While off-roading, this frame can handle the hits to the ground quite effectively.
The rigidity allows it to withstand twists better than a ladder frame.
Disadvantages of backbone chassis
The cylindrical tube covers the driveshaft, so the repair requires opening the whole backbone.
Due to high manufacturing costs, the backbone chassis adds to the price of a car.
What is a tubular chassis?
This type of chassis is mostly used while manufacturing racing cars due to the enhanced safety they offer. It creates a three-dimensional cage-like structure. The entire vehicle is designed around this chassis. The frame contains tubular pipes, hence, it is called a tubular chassis.
Advantages of tubular chassis
It offers higher rigidity than other frames with similar weight.
The balanced rigidity-and-weight ratio of this chassis allows the cars to be strong and lightweight at the same time.
Disadvantages of tubular chassis
Tubular frame designs are complicated and can’t be created using conventional methods.
Mass production of this chassis is not possible, hence the construction takes a lot of time.
It is not feasible for manufacturers to create passenger cars with this type of chassis.
The design of this chassis increases the height of the floor, making cabin access a bit difficult.
If you have any other questions, Email: Sales@obd2.ltd
Monocoque chassis
Ladder chassis
Backbone chassis
Tubular chassis
Nick6147
Aug 6, 2008 08:19 AM
