Detailing Discuss detailing your ride within...
DIY: Engine Bay Washing (Video)
Old Apr 7, 2012 | 04:24 PM
ProStreetDriver's Avatar
Default DIY: Engine Bay Washing (Video)
How to wash dirt, grease, or grim away from your engine bay. Make sure your engine is cool when you do this procedure. Spray the solution onto the engine and around the engine bay, let it soak for approximately 5 minutes, then continue to rinse off with hose or pressure washer. Let engine dry for a few hours to prevent the vehicle from running rough.
The soap I used in this video is called Spray Nine, but I'm sure there is other cleaners available which will do the same job.
Areas to take caution around when washing:
-alternator
-coils/distributor
-spark plugs
-spark plug wires
-fuse panel
-oil filling places (engine oil, transmission oil, power steering)
-brake fluid reservoir
-intake
-air filter
To protect any areas you are worried about water entering, you can cover it up with a plastic bag.
ProStreetDriver
Detailing
Sep 17, 2020 07:55 AM
ProStreetDriver
Exterior
Nov 19, 2011 06:49 AM
ProStreetDriver
Wheels and Tires
Aug 5, 2011 09:10 AM
ProStreetDriver
Wheels and Tires
Jul 29, 2011 04:37 PM
ProStreetDriver
Wheels and Tires
Jul 4, 2011 05:07 PM
