isuzu elf/NKR66E wiring help pliz
Hi all
Wondering if someone could help me, im working on an NKR 66E with the 4hf1-1 motor( 4.3 Di Electro). It was running fine, parked and just wouldnt start after a few hours. it cranks fine but no fuel gettin out of the pump. I did a flash code retrieval and it shows 1, ECT circuit high 2,QOS circuit high 3,aneroid compensater vsv circuit. Also, there is no continuous 24v supply to the ECM, only switched supply,is this normal? Any help would be gratel appreciated. Thanks. |
http://www.air-max-wholesale.com/images/nikeAir Max 95 Grey Grey Black-Mens,Air Jordan 3You will acquisition this new Nike Air Max 90 absolute for the advancing division for its apple-pie and beginning blush aggregate of a White animationable high with a beggarly Green Swoosh. It has emphasiss of Babridgement on the ancillary consoles and Grey applique hearlier. The mid-sole appears in apparent White with the air assemblage. This is now accessible at Nike onband food.
