bumpity69 |
05-05-2007 09:50 PM |
Put on a new complete head on 2.6 - now everything is hooked up ( hopefully) and I have issues.#1 -the fuel pump is not working but when jumpered off a battery it pumps great. Not sure if I messed up wiring or if I have'nt hooked up something. #2 Put a complete new head on it and am concerned that the timing or something might not be correct. Lined up all markings on gears - crank,cam and distributer. Ran compression check and all were between 125 -150 psi. when cranking have good spark but even spraying fuel in carb and it will not run. Please email or respond with ideas I need this for work.
