92/93 isuzu pickup won't stay running?
I say 92/93 cuz the title says 92 the trucks label says 93, anyways we never had problem till the coil pack wire was damaged and had to be replaced then we noticed the coil pack needng replaced to so we replaced the coil
Pack the truck runs good for 10 minutes or so then sputters bucks n sometimes dies???? Suggestions? I'm not a pro and mostly use google! So bare with me!!!! |
i hope someone chims in because i been fighting mine for over a year. i scared to drive it .. mine ran good for a while then just would die like you shut the key off. sometimes start right back up and sometimes just have to wait a min ..and go maybe 10 feet or 10 miles you never know. i have changed everything but wiring harness and computer. i guess thats next. going start with wiring harness. seems like when i unplug coil and plug back up it will start and run
I'm new to Isuzu but Got a lot of electrical troubleshooting and I like to share my experience.
This sounds like Classic loose or bad or corroded connection... the other possabilty is poor ground or not enough ground straps in the correct places. Start there, Remember Bill Says, "You can't have enough grounds !!! Regards... Bill in Central AZ |
| All times are GMT -5. The time now is 04:03 AM. |
