Towing/Wiring question
Hello!
I bought a trailer and all the necessary wires to light up the trailer properly. Also, I went and bought the little connector that should come from the car to trailer to plug it up, but Im kinda stuck. Where would I connect/splice the wires to coming from the car? Has anybody towed with their Axiom that installed their own wiring? Can anyone help me?
Originally Posted by Tony916
Anyone?
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Originally Posted by JLEMOND
YOUR AXIOM SHOULD HAVE THE TRAILER HARNESS WHICH IS PREWIRED THE SAME AS THE RODEO, SAME PART , IN THE LEFT REAR CARGO AREA , BEHIND THE PANEL, YOUR ADAPTER SHOULD PLUG RIGHT IN IF IT IS THE CORRECT ONE, JERRY
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
Thank you for your response..
#8
Did all the searching I could possibly could. All I found was this: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId= 470&LineCode=BK&PartNumber=7551481&Des cription=T railer+Wire+Harness+Adapter+-+Tow+Vehicle
and its definitely not 20 bucks. I even did a search using part numbers. Could you possibly find it for me and send me a link?
I pulled the taillights and I dont see any plug that is not being used. Do i have to unplug something and replace it with this ''''factory kit'''' ?
I''''ve never had to wire any kind of towing harness, so please forgive me if I sound like an idiot. The more elaborate you could be, there more it would help me.
Thanks a lot in advance...
Edited by: Tony916
