Front Passenger Window and reulator
Hey guys,
It's been a while since I was on here. A lot going on now.
My wife '02 Axiom's window cable broke through the plastic part of the regulator and jammed up into the pulleys. I freed the cable, but in doing so the cables came unwound from the spool at the end of the motor. The motor still works fine and the cables appear to be in good shape. I'm trying not to buy a new assembly with the motor/regulator and all. Can it be rewound? I do not know the proper winding pattern or if I can even re-spool i myself. If anyone has had this problem, even if they couldn't resolve it, I would appreciate a reply.
You'll probably have more luck here:
http://forum.planetisuzoo.com/
It's a much more active forum, and not as much spam either.
