Rear differential pinion seal is leaking
Old Jan 21, 2024 | 11:11 PM
romeroom's Avatar
Default Rear differential pinion seal is leaking
1998 Amigo 2.2L - RWD
The Rear differential pinion seal is leaking and needs replacement. I have looked online and can't seem to get a consistent part; results often show parts that are supposed to be a "direct fit" yet the specs are different from each other.
I would appreciate some help on this.
Thank you.
Old Feb 3, 2024 | 06:01 PM
romeroom's Avatar
Need urgent help, please.
I replaced the seal with the right part, fairly uneventful process. Refilled the differential with gear oil.
Took it for a drive, and there is a whine that comes from the back when let go of the gas, similar to "engine breaking." There is a noticeable vibration on the shift stick during that as well.
I will be heading out to the car again in a couple of hours or so. I would really appreciate some suggestions on what to look for.
Thank you.
duskpearl
Jan 4, 2022 08:44 PM
nethu
Sep 13, 2010 01:33 AM
nevernicecrew
Jul 26, 2010 08:17 PM
88BamaTrooper
Private 'Wanted' Classifieds
Jun 7, 2010 06:28 AM
