-   Amigo (https://isuzuforums.com/forum/amigo-19/)
-   -   Not sure if I have a blown head gasket 1999 4 CYL manual 2WD (https://isuzuforums.com/forum/amigo-19/not-sure-if-i-have-blown-head-gasket-1999-4-cyl-manual-2wd-39883/)
Zachary Keith Collett Jun 11, 2013 09:47 AM
So, the CEL is on, getting back 3 codes, cylinder 3 misfire, camshaft sensor, and the camshaft itself malfunctioning. There is white smoke, not all the time but it will happen a couple times during my morning commute to work. Car is NOT overheating. The brown sludge is very apparent in the coolant reservoir, and it goes without saying that it drives like crap. I'm almost sure it's a problem in the head, but if it isn't over heating, does that make it less of a possibility of the crack being in the head and moreso in the gasket?:confused::mad:
Spazzmodicus Apr 8, 2014 11:31 PM
They don't always overheat initially when the head gasket blows. It will progressively get worse.
