Loose front brake
Old 07-31-2008, 12:38 PM
agreendaya's Avatar
I''ve got a ''92 2WD Amigo, and I''ve noticed in the parking garage at work that there''s a clicking noise when I step on or let off the brakes, seems to come from the front driver side. Yesterday I got home, pulled the wheel off, and sure enough, the whole disk, rotor, caliper, all that jazz, is a bit loose. How do I tighten it up? It still stops just fine, just makes this noise when I brake & if I go over bumps sometimes.
Thanks!
Old 08-14-2008, 11:43 PM
pacman's Avatar
Pull off both front wheels and compare all the components. Check to see if any parts are missing, compared to the other wheel or whether any parts have become distorted or bent,causing the wheel/rotor to be loose. ...Something''s changed, so be careful. Please report back with your findings/solution.
Thanks.
G-Man
01-21-2009 02:00 PM
dpups
01-17-2009 07:35 PM
diehrdkcchiefs
08-08-2007 12:53 PM
BillTrooper
05-01-2007 09:47 AM
houptee
01-03-2007 10:09 AM
Quick Reply: Loose front brake
