Isuzu Amigo Turnsignal PRoblem
I have a 92 Isuzu Amigo 4 wheel drive. Recently the turn signal on the passenger side stoped working and the flasher noise sounded faster than usual but the signals did not work. I then replaced the bulbs in front and back but it still did not work. The drivers side signal works fine, and the four way signal works fine. Just not the right turn signal.
I don't have a manual to further help identifing where any relays are located, if that is the problem. Thanks for any help. |
Sounds like a relay. I will try to look it up in my manual later.
I can't find my fix in it, so maybe I'll find yours. Ha. |
