[img]smileys/smiley7.gif[/img]Was going to change out my front brake rotors on my 99 2wd. I pulled the rotors and could not for the life of me get the bearing hub separated from the rotor. Do these need to be pressed out or what? There shot and squeeking like crazy, any help would be appriciated!
What I did on my '92 was just whack them from behind with a rubber mallet. Since you are replacing them anyway, you could even use a regular hammer. Most likely wont damage your hubs. Once they're off, clean up the hub surface with a wire brush or what have you, then smear a bit of axle grease on there to make any future removals a breeze.
