-   Amigo (https://isuzuforums.com/forum/amigo-19/)
-   -   clutch problems (https://isuzuforums.com/forum/amigo-19/clutch-problems-2616/)
Mikeross509 Dec 3, 2008 10:45 AM
my amigo is having some go problems (4cyl-5sp-2WD)
All of a sudden when I let up on the clutch there is no friction point
you give it a bunch of gas and it barely pulls you along
I thought it was the clutch so I put in a new clutch kit (throw-out bearing, plate and clutch disc) and that did not solve anything.
Is there anything that anyone has run into this same problem and\orgive me some direction on what to check next
yetisoldier Jan 29, 2009 08:31 PM
Maybe your clutch solenoid went out, or doesn''t have any fluid.
Mikeross509 Jan 30, 2009 07:02 AM
I forgot to follow up
I didn''t put the clutch fork and the throwout bearing in the right place
after i put them together it worked fine
