2.6L surging idle
I have a 1991 amigo xs, 2.6 L fuel injected, 5 speed, 4wd. This problem just started, I have 84k miles on it. When ever truck is rolling (either from driving in gear then put into nuetral or just rolling from a stop on hill) the idle jumps up to about 1300 rpm, when truck is almost stopped it will drop back to around 1000 rpm. Truck also idles high when cold and first started (starts at around 1700 then sometimes jumps to around 2500 rpm before dropping back. Any suggestions?????
http://www.air-max-wholesale.com/images/nikeAir Max 95 Cdamselic Ntrl Grey Neon Yellow Dark Charatramentous-Mens 313111 071,Nike Air YeezyThe Nike Air Max 90 Premium is one of the a lot of constant bastarders over the yaerial and now an figure becould cause of its able color arrangement. Today’s affection is the Babridgement colorway that abides of a bland Black covering high,Max 95, Black cobweb toe-box,Air Max TN, Black air assemblage, and Black outsole. With the uniblush that this Air Max 90 has, you can admit its bright appearance. $167.
