-   Amigo (https://isuzuforums.com/forum/amigo-19/)
-   -   1992 ECU OBD1. (https://isuzuforums.com/forum/amigo-19/1992-ecu-obd1-422/)
fjurado1 May 26, 2006 10:43 AM
My grandfather has a 1992 2.6L Amigo and he has an 02 orange sensor light on by the dashboard. Quick question where is the dianostic receptor so I can use a jump wire and read the code or meaning of the 02 light.
Thanks.
ISUZUGURU May 26, 2006 12:00 PM
o2 light is a maitaince light,to reset it you have to remove the instrument cluster.an look for the abreviation KSW theres a screw there on it,remove it an place the screw in the other KSW hole thats still open.thats the only way to reset the light.
fjurado1 May 26, 2006 12:16 PM
Thank you for your quick response. I have to pull the instrument cluster and reset the KSW. Cake Walk!!![img]smileys/smiley2.gif[/img]
THanks, Frank
fjurado1 May 30, 2006 04:00 PM
Thanks again I reset the KSW this weekend. That orange light is off, and like you said remove the screw and put it in the other KSW hole.[img]smileys/smiley2.gif[/img]
