Isuzu trooper 1996 battery drain prevention
I have a 1996 trooper and only start periodically. My battery rus down because I do not run so often. I suspect the security system is running it down. Anyone suggest a simple way to avoid electric drain down between runs. pull fuse box? Obviously starting and running once in a while would work but it sits a lot and it isn't really possible.
