1995 trooper HESITATION
Ok so i just picked up this isuzu trooper with the 3.2 sohc v6 5spd with
176,000 on it. The problem is that it hesitates no matter if its in gear or in
neutral, on a cold start it starts up then dies until its warmed up, when i
press the gas pedal it wants to stall on me. I have recently replaced the
intake manifold gasket spark plugs wires coil pack and cleaned the egrv. I
put the timing light on it and it reads 10 degrees at idle if i rev it the degree
goes up i am wondering if the previous owner had put the belt on wrong or
if it had jumped a notch. also i have ran fuel injector cleaner through it. I
am just trying to get some advice on what it could be the cel (check engine
light) is not on either. any advice is appreciated
