Fuel Gauge Fix - Fuel Sending Unit
Old Feb 7, 2007 | 04:16 PM
awnicol25's Avatar
If your gas gauge is not working and you may have a check engine light on as well then you need a new fuel sending unit. Dealers may tell you that you need a new fuel pump and that a fuel sending unit is not available for your vehicle. However, this is not that case. I have Isuzu OEM/Factory fuel sending units that will fit any Rodeo and Passport from 1998-2002. You will not need to recalibrate anything and it should cost no more than $150 to install, or you can do it yourself in under 2 hours! This unit WILL fix you problem. Do not let the dealer rip you off! I fixed mine in my 2000 Rodeo 4x4 and figured I may as well help others out and save other hundreds of dollars. My item is for sale by calling Andy at (407) 625-4295 or anicol@cfl.rr.com or by looking on eBay.com for Seller awnicol25. Good luck! Save some money!
Old Feb 7, 2007 | 10:47 PM
MASTERTECH's Avatar
on the 1998 models you do need to reprogram because the resistance value is differnent from the one that came from the factory
Old Feb 10, 2007 | 03:05 AM
jburnsua's Avatar
how do you go about getting it reprogrammed? is that something only a dealer can do?
my 98 rodeo is doin the whole cel and gas gauge effin up so im gonna fix it
Old Feb 10, 2007 | 03:25 PM
awnicol25's Avatar
well, i have sold over 2,000 of these since November of 2002 and I have had 2 peolpe tll me that they had to reprogram their vehicle. I really do not think that you will need to do this, but I can not say 100%. Either way it is a good deal to buy the unit and not the entire fuel pump. Saves a lot of $. If you need a unit I have some on ebay under the seller name of awnicol25.
Andy
Old Feb 10, 2007 | 09:55 PM
MASTERTECH's Avatar
Yes you can buy the sender that is not the problem but on the 1998 models they had a different ressistance value then the 99 and up values, Trust me I work on Isuzu's everday
Old Feb 11, 2007 | 01:20 AM
awnicol25's Avatar
Good to know. Thanks Mastertech.
Andy
Old Feb 12, 2007 | 10:21 PM
MASTERTECH's Avatar
make sure you buy the sender then have it reprogrammed after the sender is replaced, I don't know if I was totally clear on my explaination or not
Old Feb 13, 2007 | 08:04 PM
jburnsua's Avatar
so do you jus go to the dealer and then get them to do reprogram the ecu and how much does it cost?
Old Feb 19, 2007 | 04:45 PM
98rodeoS's Avatar
I had a dealer tell me they would not reprogram my pcm, but they would replace the sender, I guess there is no money in the reprogramming. Trying other dealers now, but there are not many in my area. Anyone know a good one near Vancouver, BC?
Old Feb 19, 2007 | 09:27 PM
MASTERTECH's Avatar
usually they charge an hour labor
