malfunction code
Old Apr 10, 2005 | 11:14 PM
burningwind's Avatar
the check engine light in my 1998 rodeo is on. the code is evaporative emissions malfunction. what causes this code?
Old May 16, 2005 | 02:22 AM
alaskafrog's Avatar
hey have you checked the gas cap if mine is not on tight my check engine light comes on.
Old May 27, 2005 | 02:58 PM
drew's Avatar
You need the exact code. There are different levels of EVAP leaks. If the code os P0440, gross EVAP leak, it may be just the gas cap. If it is a mediuma or small leak, there is probably a cracked EVAP hose. FYI : The EVAP system monitors pressure inside the fuel tank. The reason the CEL comes on when you leave the gas cap loose is because it senses a huge pressure drop inside the tank. Hence, the term "gross" leak. Hope this helps.
MatchOneOffers
Jan 1, 2009 09:03 PM
MatchSpecialOff
Jan 1, 2009 01:18 PM
MateOneHolidayO
Dec 1, 2008 11:19 PM
Michael1243
Nov 30, 2008 12:42 AM
DRACINTHEBOX
Dec 6, 2006 04:13 PM
