Go Back   Isuzu Forums - Isuzu Enthusiasts Forum > General > General Tech
Sign in using an external account
Register Forgot Password?
Connect with Facebook
Search
Reply
Thread Tools Search this Thread Display Modes
Old 10-22-2011, 07:35 AM
The Money Pit Amigo The Money Pit Amigo is offline
Default 4x4 light flashing
Also have a blinking 4X4 light 99 Amigo. Have checked all the vac lines and everything seems to be fine. Replaced the 4x4 sol on the drivers side firewall and it does not appear to give vac on the 4x4 (gray connector) when button is pushed. When the vac lines are swapped the 4x4 does engage when the button is pushed but still blinks. I do get voltage to both the gray and the blue on the sol. It just appears that the button is not closing the blue and opening the gray sol when pushed. The blue always has constant suction.
I did just find the Diff switch wires on the front axle were rotted and not connected. I ordered a new one but i do not think it is causing the issue from what I have read in other threads. Just for the hell of it i removed the 4x4 control under the center rest and inspected it for shorts and it looks ok.
Old 10-29-2011, 07:49 PM
Black99Amigo4WD Black99Amigo4WD is offline
I have a the same truck and mine will not start and the truck will not move even in neutral. It cranks and the 4WD light flashes but no start and cannot get it to move no matter what.
Guys on other forum say I should disconnect motor on side of transfer case and then put it in neutral with pliers just to get in to a garage.
Wish I had known this was really a GM product when I bought it new! A repair every six months with this truck and the frame is as rotted as a thirty year old salt truck!
Old 11-02-2011, 11:26 AM
electricpuppyboy electricpuppyboy is offline
You'll probably have more luck here:
http://forum.planetisuzoo.com/
It's a much more active forum, and not as much spam either.
Old 11-14-2011, 07:34 PM
paulmiller156 paulmiller156 is offline
Hey I liked your same truck post & I hope you will get sell this on good time !
__________________
cars for sale
Old 12-13-2011, 01:32 AM
jakelarson jakelarson is offline
__________________
get free facebook likes
Old 01-05-2012, 12:32 AM
ethanvalit ethanvalit is offline
Old 01-13-2012, 09:40 PM
Taylorcarter Taylorcarter is offline
__________________
used car
Reply
Tags
4wd, 4x4, 99, amigo, amogo, black99amigo4wd, blinking, blinks, flashing, flasing, flasshes, isuzu, light
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
