Over fueling 1993 Rodeo
Old Feb 14, 2006 | 01:37 PM
tysmommy's Avatar
Help..............I don't know what else to do.... My 1993 Rodeo bogs out on the highway and is using an excessive amount of fuel!!! I have had the fuel filter replaced, the fuel regulator replaced, the lines cleaned and flushed, the EGR valve replaced etc and it's still performing the exact same way. I can only drive about 100kms and use half a tank of gas. Any suggestions? My mechanic is baffled at this point and doesn't have any other ideas of what could be causing it. If you have a suggestion I'd be happy to try anything at this point. Thanks in advance![img]smileys/smiley19.gif[/img]
Old Feb 14, 2006 | 05:37 PM
get him to check o2 sensor voltage,sometimes they will go bad without setting the check engine light,i twill cause heavy fuel consumption ,black smoke from exhaust,low power,an also the map sensor will do the same,make sure that has vacuum going to it an the voltages changes with engine rpm an load.if your engine leaks alot of oil,it gets on your 02 sensor an will damage it,so repair any oil leaks also.try to stay with an O.E sensor,the aftermarket dont work well at all o2 voltage should range....... 0.20v-1.0v rapidly,map......1.0v -4.0v with engine load.Edited by: ISUZUGURU
Old Feb 15, 2006 | 01:43 PM
tysmommy's Avatar
Thank you very much, I do infact have an oil leak so that may just be the problem...........I will definitely give it a try. Thanks again for your help I'll let you know how it turns out.
Shane
Dec 20, 2012 11:05 AM
dtermined1
Mar 23, 2011 10:34 AM
pkanu
Feb 14, 2009 08:27 AM
wrw1
Mar 7, 2008 10:58 PM
